So I recently bought a Ford 2006 F250 6.0 Diesel. Before I bought it, there was a lot of work done at the dealer (oil cooler, HPOP). The truck also had the EGR deleted previously. The dealer changed the coolant. But instead of putting in spec'd ford gold, they put in ford orange (V3CB), it's on the receipt. According to Ford's documentation, Ford Orange is spec'd for 2011+ (6.7L PSD) trucks, and is NOT supposed to be backwards-compatible. This is from ford:
Quote
Ford Orange: Use only when specified. Do not use this product in systems originally equipped with any green-colored, conventional engine coolant such as Motorcraft® Premium Engine Coolant, meeting Ford Specification ESE-M97B44-A, or with the yellow-colored, longer-life Motorcraft® Premium Gold Engine Coolant, meeting Ford Specification WSS-M97B51-A1, or with the dark green-colored Motorcraft® Specialty Green Engine Coolant, meeting Ford Specification WSS-M97B55-A
Reading on powerstroke.org forums, there seems to be a lot of concern with the normal factory ford gold fill due to silicates dropping out of solution and possibly plugging up the oil cooler. I don't have any true basis of how true that is but it seems repeated a lot. From what I have found, Ford Gold is a HOAT that doesn't use 2-EHA, but other organic acids. It does have low nitrites and low silicates, but no phosphate.
What I have seen written is that Navistar, who built the motor, originally spec'd Cat EC-1 coolant. This, as far as I can tell, is an ELC coolant, and I believe technically a "NOAT." It has 2-EHA along with nitrite. No nitrate, silicate, phosphate.
Now, the Ford Orange that I have in currently, is a full OAT. It also uses 2-EHA, but has no nitrite, nitrate, silicate, phosphate.
So, I would like to get some thoughts as to continuing to run Ford Orange in my 6.0 powerstroke. To me, it seems like the ford orange and ELC is basically the same except that it doesn't have nitrite in it. Nitrite is supposed to prevent damage during cavitation because it will line cylinders fast. Organic acids are also supposed to line cylinders and protect against cavitation but what I have read is that it does not do this quickly. LINK
Quote
