Originally Posted by RyanY
Not quite the answer you are looking for, but I recently did 08 Accord braked and didn't have the right size flare. Just used a 6 point socket to loosen and then an open end to lightly open/close for fluid replacement. Final torque with the socket.
Originally Posted by spasm3
Somehow from memory i'm thinking the fronts are 10mm and the rears are 8mm, But i can't swear to it. For bleeders a regular box end works well. 6 point preferably.
On my Infiniti, I also used a 6-pt socket to break loose and final tighten and it was fine. The bleeders open quite easily. I then used a box wrench to open/close them while bleeding. On my wife's Fusion, I used a 6-pt socket on the fronts but on the rears, the bleeders are kinda buried underneath and behind different components and I wasn't able to get my socket on it. My Craftsman and GearWrench wrenches are 12-pt and I always play it safe and stopped before I snapped it off or rounded it off.
I suppose a 10mm (for the Fusion) would be all I need after all and continue to use sockets. Haven't looked at the Accord's bleeders yet to see if they're easy to access.
