final say on fluids used in ATF-specced MTs
Originally Posted By: JHZR2
Too bad there is no PDS for that motorcraft oil. In reality, Saab/GM MTF0063 is fine for me. My only fear being with saab going to new owners, what happens to the fluid spec and how do I get the right fluid. Draining the fluid out on a 9-3SS isnt as easy as in most other cars due to the location of the drain plug...
There's a link to the PDS at the bottom of the linked web page:
http://www.fcsdchemicalsandlubricants.co...ion%20Fluid.pdf
Originally Posted By: MolaKule
Has anyone tried the new Ford dry clutch fluid for DCT's?...
I've used the Motorcraft DCT fluid in my Mustang GT's MT-82 and it works great, although for summer track day season I switched to the Motorcraft Full Synthetic Manual Transmission Fluid in the link above. The heavier fluid is recommended by Ford for track use in the MT-82 and the DCT is recommended for regular service.
The only things I have actually read that can happen are in certain transmissions a splash lubricated front bearing can fail from a thicker fluid not properly splashing to reach it. The other is rough cold shifts in the morning, but I don't believe any damage results.
Would an ATF really "sling" better?
Out of curiosity I called the dealer for a price on the Motorcraft Dual-Clutch Trans Fluid.
xt11qdc - $32.43 / litre
I don't think I'll be buying any anytime soon.
Originally Posted By: gtx510
Isn't BMW MTF on the thicker side also? ~10cst @ 100C? There was a VOA in the gear oil forum but I can't find it.
BMW stock fluid is thin and close to Dex III ATF in viscosity.
For BMW manual tranny calling for ATF, Amsoil MTF 5W30 is too thick in cold climates and 75W90 is way too thick. Both are significantly thicker than the stock BMW "lifetime" tranny fluid.
Royal Purple Synchromax is closer to the stock fluid.
No question that Amsoil makes great fluids but the thickness of MTF aggravated shift pin issues in my tranny at cool temperatures (10C or lower). It is fine for warm weather and might be ok in the cold if you don't have any shift pin issues.
In my BMW I have tried the stock fluid, M1 Dex III, Amsoil MTF, Dex VI and RP Synchromax. I have experienced the best shift quality with the Royal Purple over a wide range of temperatures.
I recommend sticking with something that has viscosity specs close to the stock fluid.
BMW MTF-LT-1 (Stock Original BMW Z3 Fluid)
Viscosity at 40C = 37.5 cSt
Viscosity at 100C = 7.5 cSt
Amsoil 75W90 for manual transmission
Viscosity at 40C = 88.4 cSt
Viscosity at 100C = 14.8 cSt
Pour point = -46C
Amsoil MTF
Vicosity at 40C = 47.1 cSt
Viscosity at 100C = 9.6 cSt
Pour point = -45C
RP Synchromax
Vicosity at 40C = 38 cSt
Viscosity at 100C = 7.7 cSt
Pour point = -54C
Dex III (Mobil 1 ATF Specs)
Vicosity at 40C = 36.3 cSt
Viscosity at 100C = 7.4 cSt
Pour point = -51C
Pentosin MTF 75W80 (meets BMW MTF-LT-2)
Vicosity at 40C = 38.3 cSt
Pour point = -60C
Amsoil Multi-vehicle ATF
Vicosity at 40C = 38.8 cSt
Pour point = -53C
Redline makes 70w80 and 75w85 gl-4 gear oils now also.
I'd post a link but they sell it on the same page.
just google redline oil.
70w80
API Service Class GL 4
SAE Viscosity Grade (Motor Oil) 5W30
SAE Viscosity Grade (Gear Oil) 70W80
Vis @ 100°C, cSt 10.6
Vis @ 40°C, cSt 56.2
Viscosity Index 183
Pour Point, °C -50
Pour Point, °F -58
Flash Point, °C 232
Flash Point, °F 450
Brookfield Viscosity @ -40°C, Poise 120
75w85
SAE Viscosity Grade (Gear Oil) 75W85
Vis @ 100°C 12.0
Vis @ 40°C 64.3
Viscosity Index 172
Pour Point, °C -48
Pour Point, °F -54
Flash Point, °C 236
Flash Point, °F 457
Brookfield Viscosity @ -40°C, Poise 160
Both of those Redline oils are too thick for a manual transmission application that calls for ATF.
Look for something with 100C viscosity under 8 cst.
