Originally Posted By: mongo161
The ONLY problem that I see with putting any magnet on an oil filter is this.....
If you go to get some work done on a vehicle....and an unscrupulous mechanic happens to see and want that magnet it will disappear fast.
Not only will your good magnet disappear....but think of the consequences of his action. All the iron and steel that the magnet had trapped suddenly is re-released back into the oil flow in a sudden plume of metal particles.... when the engine is turned back on.
IMO....that damage is irreversible and the particles that were trapped would be felt and seen big time in wear to the engine. That start up may sound worse than any failure of a ADBV or Dry Start ever experienced.
I think that's a null issue really.....for one, take your car to mechanics you trust, and/or b, review their work with them after they perform their service. I've always done that.....one time I took my car in to get a battery changed out, they put the battery in fine, np, but when I came out to the car, they left their wrench(es) under the hood, and didn't even re-connect the hold-down bar for the battery. Needless to say, I connected the hold-down and got a new set of tools I didn't really need
But yea, you do make a good point, if a mechanic really wanted to be a "wise [censored]" per se, noticed the magnet, and KNEW what it was used for.....sure, he could take it off, crank the car over for a little spin around the block, then put it back on.....potentially causing some damage....since the "previously" suspended metals on the magnet would now be going through the engine....
