OVERKILL
$100 Site Donor 2021
Originally Posted By: Fitz98
This Lock N Stitch kit looks very well engineered. Looks challenging to do without removing the head. Have you done this in the vehicle before?
It was done in the vehicle by the machine shop, yes. This was done at the Ford dealer as I wasn't above to fight with cylinder #4 myself and I wanted to be certain that I had a fix that was permanent.
I knew that the lock-n-stitch one was the ONLY one approved by Ford, and this was of course the one they used at the dealer.
Pricing was reasonable and this insert cannot (as you've probably noted from the documentation) back out like a heli-coil can. It is a permanent fix that makes the threads in the affected cylinder better than those on the rest of the plugs in the engine. If I had been able to afford it and the downtime when it happened I would have had all eight holes done for the peace of mind.
