Car is a 2001 Subaru Outback with the H6. This is the boxer motor for those that don't know Subies. Anyway, bought the car used, runs like a charm, but twice now, after changing the oil there has been a loud 'clacking' for lack of a better word for about 5-10 seconds. I've only heard this noise after changing the oil.
The first time I changed the oil I didn't pre-fill the filter, as it sits horizontally, and I figured some would leak out. I attributed the noise to the dry filter. So the second time (last night) I pre filled the filter, so when I turned it on it's side, a bit of oil began leaking out. However, I got the same clacking when I started the car.
I'm wondering if I should change my oil changing method? I let the oil drain till not even a drop comes out of the drain hole. The drain hole is angled down to the passenger side and since the car is jacked up from the driver's side, I'm guessing even more oil than normal comes out. Should I shorten my drain time, or is there some way to pre-lube the engine before starting it - disable the fuel pump and crank the engine for example?
