Originally Posted By: KCJeep
Originally Posted By: RamFan
Originally Posted By: GMBoy
I would take an ecore over a Fram orange can.
Interesting. I'm the opposite, if I had the choice between the two, OCOD would be getting used.
Me too, the ecore has the feature most Fram hater's can't stand (flimsy media caps) but they are much worse than Fram's in both strength and adhesion. Then you can add a plastic center cage instead of a steel tube, media that flattens and blows out through the cage into the engine, and a "combo" ADBV/Bypass valve that doesn't work well or at all. Quite a deal those ecores, but at least they are not orange, eh?
Ok - all good points. But between these two poor choices, the eCore usually has the better filter media so that would steer me in the ecore direction.
