E5 Ethanol at the pump?
North Dakota
I've never seen E5 on a pump before, is this common? I was traveling through eastern NE so right in the corn belt but I always just expect E10 on up. I find it interesting that the content sticker, though, is placarded on both grades stating up to 10%.
I use BP ultimate most of the time since it came out. Pumps say up to 10 percent ethanol. Mid grade is also dropped separately and is not a mix. I also get the most mpg using this gas.
Could they be blending premium & regular to make plus? I know that used to be a Sunoco thing.
Almost certainly what they're doing. In the case of this pump (with 87 and 91 fuel), a 50/50 mix gives 89, but are percentages split 50/50 ? May not matter because that sticker covers both the 87 and 89 nozzles and covers their bases with "up to" 10%.
