--quote--
Heavy duty diesel Sequences
E2..General purpose oil for naturally aspirated and turbocharged heavy-duty diesel engines, medium to heavy duty cycles and mostly normal oil drain intervals.
E3..This lubricant category provides effective control with respect to piston cleanliness, bore polishing, wear, soot handling and lubricant stability. It is therefore recommended for diesel engines meeting Euro 1 and Euro 2 emission
requirements running under severe conditions. It is also suitable for extended oil drain intervals according to the manufacturer’s recommendations.
E4..Stable, stay-in-grade oil providing further control of piston cleanliness, wear, soot handling and lubricant stability compared to E3. It is recommended for highly rated diesel engines meeting Euro 1, Euro 2 and Euro 3 emission requirements and running under very severe conditions, e.g. significantly extended oil drain intervals according to the manufacturers recommendations.
E5..Stable, stay-in-grade oil providing effective control with respect to piston cleanliness and bore polishing. It further provides improved wear and turbocharger deposit control, soot handling and lubricant stability compared to E3. It is recommended for highly rated diesel engines meeting Euro 1, Euro 2 and Euro 3 emission requirements and running under severe conditions, e.g. extended oil drain intervals according to the manufacturers recommendations.
--end quote--
http://www.acea.be/ACEA/20020618PublicationsOilSequences.pdf
See pages 4 & 9
Ken
