Originally Posted By: Bror Jace
MMO is NOT silly snake oil only used by rubes that don't know any better.
I use MMO in my fuel as one of my UCLs (upper cylinder lubes). I use a lot of UCLs when engines are new, trying to make for a more gradual break-in process, hoping for a tighter engine with greater compression and lower oil consumption. I can't speak to the compression, but oil consumption in all my engines (automotive as well as OPE) is notoriously low ... even nonexistent.
Gasoline, especially blended with ethanol, has poor lubricity. Adding a UCL can reduce cylinder/piston ring wear, intake vale seat wear (on non-direct injected engines), lube the fuel pump and injectors. It reduces fuel consumption by a small percentage and reduces oil consumption by reducing/replacing the sump oil that gets drawn up out of the sump, past the rings, and burned in the combustion chambers.
I have also used it once in a while in the oil as a very mild cleaner ... adding it a few hundred miles before I drain the sump. However, due to careful maintenance with high quality lubricants, I can't say I have much need for sump cleaners. If I bought something used with a questionable maintenance history, I might reconsider.
All of which means nothing, right? I mean, I've never used MMO or any "UCL" or any other additive (except Techron once in my BMW), and I don't have dead fuel pumps or excessive oil consumption. In fact, my 1NZ-FE uses about 1/2 quart every 6000 miles and that's on 0W-20 in the summer. I didn't use any additives when I bought the cars and I ran both Toyotas out to the scheduled OCI on the factory fill. If there is something in my "upper cylinder" or my fuel pump or my injectors that needs lubing, I sure don't know what it is. Lack of harm doesn't equate to a benefit, I may think it is a good idea to add a stick of butter to my fuel tank every 6 months and I may have been doing that for 20 years with no problem. But unless I have something to compare it against I have no clue whether it helped or harmed.
And you say its a very mild cleaner - how do you know that? You think it is, but you don't know if in fact it does anything at all, do you?
Oh, and all I've ever used is E10. We live in a non-attainment area and it's all that's been available for many years. I'm not sure what fuel "lubricity" really is to be honest. Why does it need to be lubricious?
Please don't take this as a rant against MMO. It's just that all the stuff you say in your post means nothing to me or anyone else here about the effectiveness of the product - which is typical, because determining real effectiveness would be a very difficult task.
