Good evening all!
I work in a lab that tests turbo-shaft engines. As you'd imagine, we have a tank farm and always have JP-8 jet fuel readily available.
We run our Yanmar-powered diesel equipment on the JP-8 with seemingly no ill effects. It's handy, easy, and far cheaper than trucking in and maintaining a diesel tank/pump system.
Months ago, I read that JP-8 doesn't have the same lubricity as diesel, and therefore a lubricity additive is required to prevent early failure of injection pumps. We started using a very healthy dose of Power Service additive with the Slick Diesel additive. As usual, the equipment runs great.
Yet, a few weeks ago, I was reading that when the Army started using JP-8 in all turbo-shaft and recip diesels to lower logistics costs, they studied the lubricity issue and found no ill effects due to the lower lubricity of JP-8 vice diesel. The best I could tell, the test engines were 6.2L GM diesel V-8's.
Yanmar / John Deere recommend lubricity additive for "diesel fuel of unknown or low lubricity." They don't mention JP-8.
Looking for opinions from folks who may have experience running JP-8 in diesel engines. Any injection pump failures traceable to JP-8 usage? Think that the additive is required?
On one hand, the additive is cheap. Yet, on the other hand, we like to keep costs as low as we can.
thanks much,
ben
thanks much,
ben
