dragboat, I thought some newer gas designs were using compression to assist ring seal? (diff pressures between top and 2nd ring) Pretty sure the LS1 was one of these along with some Japanese designs?quote:
Originally posted by dragboat:
Quote:
Actually a gas motor rely's on ring tension to seal.Some have more tension than others. Now a race piston ie a NHRA Pro Stock class motor uses a gas ported piston design which helps ring seal on those 14.1 and up compression motors.
I have been led to believe through reading Calcium Phenates and Calcium Sulphonates are organics which are not Metallics like the inorganic ZDDP's and Moly Disulphides/Disulphates.quote:
Originally posted by ben walker:
Dragboat, keep on mind the same additives used in gas spark engines are used in diesel oil as well. Calcium, magnesium, zinc, moly, phosphorus are all metalic additives.
Ok SA oil it is from now on,,I cannot get through the fact that I used a high overbase just as a gest so I give up,,you winquote:
Dont use amsoil or any other premium oil for that matter as they all have high levels of mettalic additives. I really dont see how you equat bore polishi8ng with mettalic additves. Zinc would have avery hard time polishing anything as it is a very soft metal.
They might be using a gas acummulator groove in the piston like this ?quote:
David
But we're not talking about the metal, zinc. We're talking about zinc dialkyl dithiophosphate or zinc diaryl dithiophosphate. That is NOT zinc.quote:
