Car is a 2000 Citroën Xsara 1.6 16v that belongs to a relative. TU5JP4 engine, less than 100,000 km. The story is that it started smoking heavily on start up and go through a ton of coolant. The oil was a milkshake but it wasn't that bad. Removed the plugs to see what was lurking in there. 3 cylinders were fine, but i could scrape a bunch of rust and water on one piston. Of course the cooling system looks shockingly bad, filled with liquid rust. Decided to pull the head to see if the headgasket is the issue and to have a look at the cylinder. Here it is:
Not sure you can see it but the plating is falling apart, i could peel if off with my nail. Headgasket appears to be fine. I think the issue is just corrosion or caviation eating through the sleeve. What do you think?
