In my opinion, the side valve Briggs is amoung the best small engine ever made. I have been collecting, working on, selling, and using garden tractors for 30 years. I have a stable of 30 or so tractors so I am not speaking out my [censored]. Examples; I have a 1992 WheelHorse 212-h with 1800 hrs. on the 12 hp I/C and it runs perfectly and uses no oil between changes, I have a early 90's Bolens ST with a 10 HP PowerBuilt (aluminum bore) with 2200 hrs, a 72 Toro 8-26 snowblower that still runs perfectly...i would bet a months pay that it would start on the second pull after setting all summer. I could go on with several more examples, In my book, it ranks right there with a K Series Kohler if not better. They are about the most indestructible engines ever...heck, you can run them on used oil, vegetable oil...just keep running...I have an old Grants 3.5 HP push mower that I use as a brush hog to do the sides of my driveway, it is missing one front wheel and hasnt had an air filter on it in 15 years yet I mow along the side of my gravel drive in the middle of a dust storm thats so bad you cant see me...still going. The newer OHV engines pale in comparison, I only regard the Vanguard as somewhat decent,as is the Kohler Command, but the manufacturers have gone to the Intecs and courage engines as the former are expensive. The Courage engines are throwing rods faster than they can fix them and are very lucky to see 500 hrs. Same with the Intec but a little better, they bend push rods. One of the problems I see as a cause for these failures, pushing more horsepower than the block can handle. For instance, a 17 hp Briggs or Kohler single has far fewer problems than he 21 hp engines. The crank cases are flexing under high pto load and they flex as much as .010...there goes the crank bearing. Lets not even touch Onans, still pushrods, still 3k hrs with ease. Only used in skidsteers now a days. The companies didnt switch to the ohv design for durability, they did it for emissions to get better placement of the valves for more complete combustion. They do not produce more torque in the real world...you can search for dyno tests of side valves and see an old 12 hp Briggs pushing 25 lb. ft. of torque, thats more than a 17 hp ohv at about 22.
