Looking at purchasing a used motorhome with a 2009 Cummins ISL 425 that has right at 52,000 miles and is in what I would call above average shape. Not perfect but much nicer than anything else we've looked at in that vintage. Kept in an insulated garage, always connected to shore power, all "house" systems are in excellent shape and there's a stack of maintenance records for everything pertaining to the RV side of this thing. They’ve always had a warranty on it so as something broke, they had it repaired or replaced.
Curiously, there are relatively few chassis maintenance records. In the 5” thick folder of receipts, etc., I can only find 3 chassis maintenance records.
June 2014 – No Mileage Listed on the work order but based on other service records from that time frame, I believe it was around 30K miles.
Sept. 2016 – No Mileage Listed and I don’t see any other records to indicate what it would have been around that time.
July 2017 – 43,500
Present – 52,000
If that information is complete and accurate, it’s been 4 years since the last oil change but only 8,500 miles. Suboptimal for sure. Given the condition of the rest of the RV, I'm not inclined to think they were intentionally neglectful of the chassis maintenance but in the spirit of trust but verify, I had an oil analysis done.
The big red flag is Iron but given it’s possibly 4 years and very limited use, I’m not sure if that’s just a result of not changing the oil or if there’s a significant issue brewing. I’m hoping someone can help interpret some of the rest of the results as they might relate to high iron. I’d like to think that the Iron reading being so high is an anomaly and there would be other markers to be concerned with. Perhaps that's wishful thinking based on the emotional and financial investment thus far.
Below are the results. The analysis report from JG lubricant suggests that a fluid/filter change is the only recommended action.
Anyone have any words of wisdom?
Wear Metals
Iron – 190
Chromium – 5
Nickel – 1
Aluminum – 42
Copper – 60
Lead – 2
Tin – 1
Cadmium, Silver, & Vanadium – 0
Contaminant Metals
Silicon – 9
Sodium – 5
Potassium – 38
Multi-Source Metals
Titanium – 1
Molybdenum – 56
Antimony – 0
Manganese – 3
Lithium – 0
Boron – 18
Additive Metals
Magnesium – 831
Calcium – 1258
Barium – 0
Phosphorus – 1000
Zinc – 1216
Contaminants
Fuel Dilution - Soot - Water
Fluid Properties:
Viscosity (100* C) – 13.0
Base #D4739 – 5.80
Oxidation – 15
Nitration – 12
July 2017 – 43,500
Present – 52,000
Wear Metals
Iron – 190
Chromium – 5
Nickel – 1
Aluminum – 42
Copper – 60
Lead – 2
Tin – 1
Contaminant Metals
Silicon – 9
Sodium – 5
Potassium – 38
Multi-Source Metals
Titanium – 1
Molybdenum – 56
Antimony – 0
Manganese – 3
Lithium – 0
Boron – 18
Additive Metals
Magnesium – 831
Calcium – 1258
Barium – 0
Phosphorus – 1000
Zinc – 1216
Contaminants
Fluid Properties:
Base #D4739 – 5.80
Oxidation – 15
Nitration – 12
