Originally Posted By: omegaspeedy
Has anyone thought that some of these cars may not actually be burning oil due to bypass of the rings, but instead the PCV system is a 'thirsty' one. i.e. due to it's possible poor design, it allows excessive amounts of vaporised oil to escape via the PCV system where its just burnt?
For anyone worried about excessive burn, install an effective catch can and see if its just escaping via that system. If this is the case, theres an easy fix.
it does seem to be more the performance engines. while the spark is on the list its numbers are almost insignificant. could it be something like people driving them harder? or piston oil squirters putting more mist into the crankcase air that gets sucked out? maybe to protect them better they design them to burn oil so its like a 2 stroke and lubricates the inside of the combustion chamber too
maybe turbo's heat the oil so much it just all evaporates away!
noack volitility test many syns have 10% evaporation after an hour of high shear at 300F right? so on a 5L sump thats 0.5L right there! lol
the other thing with some of these cars having extended oci's- as soon as you start adding oil you can go farther on that 'oil change'. maybe in the interest of 'you can do less oil changes on our car than our competitors car' they design it to burn oil so you add some and boost the additives
