Through search, I found some different techniques for bleeding the system, still unsure.
2006 tC:
So I decided that I would drain the radiator and refill w/ toyota super long life coolant every 30k miles, just to be safe.
I drained the rad no problem, tightened everything back up, and poured just about an entire gallon of coolant through the radiator cap.
Squeezed the hoses some, saw some air bubbles come out. Filled it to the top, but did not notice coolant coming out of the bleeder valve on top of the radiator (more on this later).
Put the cap back on, started the car and got it to operating temp. Ran the heat, it came out hot. Let it cool, opened the cap, added a little more coolant as well as a small amount in the reservoir. Is this enough??
The FSM says to attach a vinyl tube to the bleeder valve and to open the plug by 3 turns ( I did this)
However, nothing came out...hmm?
Should I be undoing this air valve while the engine is running? With the radiator cap off?
What should I do?
The heat works fine, doesn't seem to overheat @ idle. I did add a small amount to the reservoir as I noticed it dip slightly after a 5 minute test drive.
2006 tC:
What should I do?
