Folks, I have a confession to make. As many of you know, I LOATHE Dexcool. We all know the horror stories: sludge, rust, gasket deterioriation, more sludge, etc. I've made more than my share of rants on the matter- and I still stand by MOST of them.
But in my rage against corrosion and crud, I've strayed from the straight and narrow... worse yet, I've led others astray. My only excuses are youth and ignorance (at the time), and just plain ignorance up until yesterday.
On several occasions, I included in my anti-Dexcool rants a sub-rant regarding problems that I personally witnessed with Cummins N14 head gaskets... problems that I loudly and repeatedly attributed to Dexcool. But yesterday during some tangentially related googling (looking up info on Detroit Diesel Power Cool Plus, incidentally), I came across information indicating that I've been wrong all these years- and have attributed these Cummins gasket failures to the WRONG coolant.
See rants here:
http://www.bobistheoilguy.com/forums/ubb...rue#Post1466971
http://www.bobistheoilguy.com/forums/ubb...true#Post941360
http://www.bobistheoilguy.com/forums/ubb...true#Post847011
http://www.bobistheoilguy.com/forums/ubb...true#Post846998
http://www.bobistheoilguy.com/forums/ubb...true#Post846988
http://www.bobistheoilguy.com/forums/ubb...true#Post832636
These gasket failures occurred in the mid-late 90's, back when Dexcool was a newfangled product... and most folks assumed that red coolant = dexcool. That was my assumption... which I held onto WAY too long. Now, I wasn't entirely wrong. The coolant was red. And it was made by Texaco. It MAY have even used 2eha at the time (I haven't been able to confirm or falsify this). But I learned yesterday that the coolant in question is in fact Texaco Extended Life: a 'NOAT' coolant.
Specific info on the incompatibility between Texaco ELC and certain Cummins and GM gaskets- and how this has been addressed- is available at the following links:
http://www.radiatorreporter.com/cummtext.htm
http://www.penray.com/images/TechnicalBulletinTexaco.pdf
http://www.ryderfleetproducts.com/cgi-bin/ryderfp/products/srm/oid/125683/erm/product_detail.jsp
This is consistent with my experience with ELC coolants. As I've stated within several of the rants that I linked to- in my 14 years of diesel-mechanicing, with the exception of these Cummins gasket problems, I've Seen very few issues with ELC coolants in diesel applications. Certainly fewer than I've seen with more conventional SCA-type coolants.
And now that I can conclusively separate Texaco ELC problems from those of other NOAT coolants, I can confidently recommend their use. That's not to say that NOBODY has had problems with assorted NOAT coolants- I've heard that Navistar doesn't approve of their use in powerstroke engines. But in my own extensive experience with Cummins, Case, John Deere, and Detroit products, I've seen no reason NOT to use a NOAT coolant in most diesel applications... with the exception of Texaco.
So in conclusion, I still don't like Dexcool. I still will not use it in my own vehicles, nor will I recommend it to others. We all KNOW that it causes sludge, and I think we've done a decent job of establishing when, where, and why this happens. But Dexcool does not attack Cummins head gaskets as far as I know.
See rants here:
