Coolant analysis
Near the beach in Delaware
Will a standard coolant analysis detect salt water?
The engine is a boat engine with closed cooling. A leak in the heat exchanger could introduce salt water into the cooling system.
I have a unused WIX cooling analysis sitting on the shelf.
I would have thought a pool test kit Chloride test would be cheaper, easier and just as accurate.
The Chloride levels of salt water are pretty consistent unless you are boating in the dead sea.
