Originally posted by Phoenix:
I agree, if the only way to damage filters is excessive pressure on the media, then the bypass valves are defective and not doing what it is supposed to do, which is a manufacture issue and not an end user issue.
I'm glad you can say that with a straight face. So the only way a by-pass valve can fail is because it was defective. Wonder how you'll do explaining to some GM owners who have theirs in the block and the by-pass fails after 50 or 100,000 miles or so (or maybe never). If one of their valves takes that long to fail, why do you think the same construction in a filter which is changed every oil change can't last? But even if the construction is different, what circumstances would lead to a particular failure? Just a bad part according to you. You may want to consider what can lodge in the by-pass valve to cause a problem. Try reading the collapsed center bulletin and contaminant lodging in the oil pressure regulating valve for instance. But nah..it's just a bad part that's all it can be. Ho-ho-ho
What percentage of auto owners or even oil change shops cut open filters?
More than you would know.
I would venture a very very small fraction of a percent.
Comparatively to everyone who owns a vehicle your right. But a significant percent still do. Much like polls don't need to poll every voter, you can get a representative sample from those who do. In fact sometimes filter companies will routinely do it themselves. Either in conjunction with some customers or when new product is in the field testing phase, they'll be returned for anylsis. Which will included cutting the filters open. ( but then again they have all the data on the filters use)
Every failure reported here represents tens (possibly hundreds) of thousands failures that are unknown.
You may be onto something. But by the same token as every filter company has a warranty department which will have X amount of filters returned annually, they all EQUALLY have Y amount in your category.
Something to think about.
Agreed..
