Originally Posted By: ebc
Greetings,
I tried using a clay bar for cleaning the finish on my car. Not sure I am doing it right since I found imbedded dirt and bug spots after the job. I used the quick detailer lubricant liberally. The clay seemed quite stiff even after kneeding for several minutes. Any suggestions appreciated. Is there a better product for clear coat cleaning?
Regards,
EBC
I am not sure which clay kit you used, but I use the Clay Magic Blue kit (~$12). Clay Magic is well liked by those who post on the Autopia site. Detailing clay is quite stiff from my experience, though this may not be the case for every brand. I usually cut each clay bar into 6 pieces and designate one piece for a section on my car. I then spray the pieces with lubricant and place them in Ziploc bags so that each piece will be ready when they are needed. I am no expert on the subject, but have done a lot of research on various sites about using detailing clay.
I recommend against using dish detergent to wash your car. Clay removes some wax, so just be sure to use it only if you plan to apply wax afterwards. Use a decent car soap, such as NXT or Gold Class wash from Meguiars. Eagle One makes a good wash soap as well. Use clay on small sections (typically 2' x 2') and be sure to use a liberal amount of lubricant. Meguiars Ultimate Quick Detailer is a good lubricant choice if you find you are running low. YouTube has a few videos that demonstrate how to use detailing clay. It sounds like you already know about using clay though.
One word of caution about using detailing clay. It can grab your paint and cause mar marks, even if you use enough lubricant. This seems to happen when there are a lot of contaminants on the paint. Some folks advise against using clay unless you plan to use a buffer, such as the Porter Cable 7424, to polish afterwards. Usually, however, the risk is minimal and clay works as intended.
