Originally Posted By: clinebarger
OK, I would highly recommend draining the fuel tank before starting your new engine! Also have the Injectors Flowed/Tested, Flush the fuel lines etc. I had a customer let his 6.0L Chevy sit for a few years....When he went to crank it up....An Injector stuck open, Flooded the Cylinder, Hydro-Locked the engine & Bent a Connecting Rod. The other 7 Injectors were stuck closed....Go figure? The fuel we have had for the past 15 years goes bad FAST.
As far as the rev limiter, They are set very conservative for what a Bottom end/Valvetrain can handle. If them "Free Revving" the engine could really cause this....I would be a lot busier than I am now. Engines are one of the most bullet proof parts of an automobile as long as they don't get hot or ran out of oil.
A Honda being stouter than a GM engine, Really? You seem to have a level head on your shoulders?
I plan on following that advice on draining the tank, flushing the lines and checking the injectors. As to Honda engines being stouter, I meant they can spin a lot higher, but in this case, yeah, I think they are. With GMs, I've had great luck with the LS, 5.7 Vortex and other V8 small blocks. Not so much with the smaller engines. I would much prefer almost any Honda engine to this 5-cyl or any of the 60 degree V-6s. Personal experience and opinion only.
I'll check out the valve seat once I have the truck back together and have time to pull the head. If that's the problem, I'll ditch the suspicion about the smog shop.
