Rest of my quote....
Originally Posted by Shannow
It's about tribofilm formation on metal surfaces, using previously used oil, most of which was past it's condemnation limit with respect to TBN/TAN, or thickening.
Used oil forms tribofilms quicker and better...it's been pretty standard knowledge forever, as in order to form tribofilms, the virgin additives have to break down some.
Doesn't mean that new oil eliminates the tribofilm (the argument against changing your oil), or that extended oil drains reduce wear.
If you believe that it does, I can offer you some "preconditioned oil" to use as an additive., in litre bottles for $20/L, you pay for the shipping
Test used a cam and follower rig.
Test used oil removed from taxis, some of which had increased viscosity by double, some of which had no TBN, some of which had TBN below TAN
They applied the used oils to the rig, and measured tribofilm formation.
The used oil, exactly as it should have, being already partly reacted formed quicker and thicker tribofilms than the new, which had to make these reactive species in order to create the films.
In most cases the used oil had no reason being in any engine in the first place.
Edit...I've got the paper, that's why I can try (failing hopelessly) to correct beliefs (not you) that are spread based on the synopsis.
