just a quick question, i am going to do an auto rx treatment and the directions say to change the filter at about 1200 mi, when i take the filter off will all of the oil drain out?
Some of it, but not all of it. What is sitting in the lines above and into the filter will.
After you put a new filter on, check the oil level and add until full again.
+1 (it's not a lot but keep a pan under your filter so you do don't have a "gulf oil spill" in your driveway, a pint looks like a lot more than it sounds...Hehehe) Women, especially don't like to see those when they come home.
Nor do landlords and neighbors. My neighbors next door, who I share my driveway with and whose son owns this apartment, were all pulling in when I did my last filter change - just as I'd taken off the filter, and (as I had not used a drain pan) just as it was visibly doing its mini gusher onto the driveway. As they had just resurfaced the driveway the day before, I could not have picked a worse time to change the filter while forgetting to use a drain pan.
I thoroughly cleaned the spill and all was well. But I won't forget the pan again.
