Originally Posted By: KrisZ
Tell, how is this major automotive company goinng to acomplish that, when part of API and ISLAC specification is backward spec compatibility and ability to mix different API certified oils?
every single bottle in my oil stash says that it is compatible with other oils.
i only buy GM4718M spec'ed oils. i only buy on sale and rebate. some rebates want you to send in bottle rings. because of this, i rarely use the same oil even two times in a row... therefore, i am mixing oils almost every oil change as only a given percentage of oil comes out during an oil change...
my point being. i have little fear of add pack interaction. i have bigger issues to worry about.
if this were a real issue, i would be prone to consistently run the same oil every oil change.
