Originally Posted By: joegreen
Today i got the forward clutch pack setup and i have a few questions on what i did. First off i am using the atsg manual and ron sessions how to work with and modify the th400. The atsg manual says to use a clearance of .010" for every friction used which would lead me to set the forward clutch pack at .050" clearance.
Ron sessions book gives a different spec for the "ideal" forward clutch pack clearance.
I used a .0600" waved plate on the bottom and all the other steels are the thin .077". I got a total clearance of about .046" to .047". Im not sure if i should leave it at that or try to decrease the clutch pack clearance per ron sessions book?
I measured the clutch hub thickness where the friction would touch and it measured .162". I found two steel plates that when added together came out to .163". I used those two steels on the top of the friction and then used a dial indicator and compressed air to get my clutch clearance measurement of .046-.047. Did i measure that properly? I used two steel plates instead of the hub because the hub could not drop all the way down on top of the frictions because of a little lip on the drum.
Before I go off..... Your .046-.047. measured clearance is good, Your method of measuring seems sound....Don't change a thing.
I use the .010" per friction rule on TH400/4L80E's.....Especially when using flat faced frictions. The Forward Hub & Forward Frictions overrun in reverse, They NEED room to separate & freewheel.
As little as .030" is permissible on A LOT of units for the Forward Clutch....But not on TH400/4L80E & here is why.
In reverse, The directs are applied allowing the forward clutch drum to "drive" the direct drum via the direct clutch hub that is also the backing plate for the forward clutch.
With the direct frictions clamped down on the direct clutch hub, It can no longer float in the forward drum, This is why there is a stop machined in the drum....To keep the direct clutch hub from dragging on the frictions.
IF you run to tight a clearance the top friction will end up ABOVE the stop with the direct clutch hub resting right on the friction with no way for them to separate & cleanly overrun.
I am not dragging anyone's build techniques through the mud.....To many builders try the same techniques on every unit when they need to have a good handle on the operational differences before making engineering changes in the name of durability/comfort.
I know why Ron states that tight of clearance.....To soften the "garage shift" into forward gears, The tighter clearance prevents the piston from building to much speed & slamming into the clutch pack, This gets exaggerated with a higher minimum regulated line pressure from heavy pressure regulator springs &/or omitting the wave plate.
With luxury vehicles/picky customers/big cam cars that idle real high & don't make any horsepower.....
I run 2 or 3 wave plates in the forward clutch.
On big power & extreme heavy duty vehicles that need all the forward clamping force available....I run what's referred to as a "Feed-Bleed" set-up. I take a aluminum TH400 piston that has a checkball in it, Drill out the checkball retaining tabs, Install a steel cup plug & drill a .020"-.030" hole in the cup plug depending on the application.
The fluid exhausted from the bleed hole slows down the piston 'til the wave flattens out & plugs the bleed orifice.
A picture of my personal 4L80E forward piston with the feed-bleed set-up.....Softer apply, Maximum clamping, Adequate clearance.
