Most manufacturers only claim their torque wrenches will be accurate from 20% to 100% of full scale.
For example, here's what Snap-On says:
http://www1.snapon.com/display/901/WWW/Downloads/CatalogPages/CAT1000i_Torque_Tools.pdf
Quote:
All Snap-on® Torque Wrenches, Drivers and Testers are provided with a Certificate of Calibration. All wrenches and drivers are calibrated
per ASME B-107-14 and ISO 6789 Standards for Accuracy, from 20% to 100% of full scale, using NIST traceable equipment.
So, you should be using a torque wrench where your desired torque is between 20% and 100% of the wrench's capacity.
This is why I have 5 torque wrenches, and I'm only a DIY'er. The lower torque wrenches are the ones I use the most. I have a 1/4" drive beam wrench rated up to 100 in lbs, a 50 - 250 in-lbs wrench, a couple 15 - 75 ft-lbs wrenches and a 150 ft-lbs wrench that is mostly used for torquing wheels. There may be one or two more I'm forgetting.
