In the past I have used a turkey baster to remove power steering fluid or brake fluid. But have found I usually make a mess. The other day I was at Menard's and checked out the automotive section. They carry a bulb type battery filler. So I bought one and tried it out. The tube is more narrow so it can fit into the cell of a battery and the bulb is larger then a turkey baster bulb so it holds more. It works faster then a turkey baster and does not make a mess. With it being acid resistant I figure it should also last longer. Just thought I would mention it.
