To get an idea of how well a V rated winter can do in hot temps, read this short article: http://www.hendonpub.com/resources/articlearchive/details.aspx?ID=574
"......................the Los Angeles County Sheriff’s Department tested a Pirelli V-rated, 17-inch snow tire on a Ford CVPI. This test was part of Ford’s ongoing brake pad development. The snow tire was Pirelli’s Sottozero Winter 240, a Severe Snow Service-rated tire, and embossed as such with the snowflake-on-the-mountain symbol."
"In the 90-degrees F heat of Los Angeles, the snow compound did not have the same dry traction as the factory original Goodyear Eagle RS-A. However, it was close."
"The Sottozero snow tires were a little less responsive than the All-Season tires on the initial turn-in for the corners. The drivers had to turn in a bit sooner because the turn-in took a bit longer. However, the Sottozero tires were stable and predictable while cornering, according to both LAPD and LASD drivers."
