Thanks I'll try that.
According to this guy, if I add more fluid and let it gravity drain through the bleeder, fluid displaces the air, if I'm not mistaken. I want to learn how to do it and flush the brake fluid at least once a year.
"Just finished mine. You do not need a vacuum pump. Just a small piece of tubing to fit over the bleed fitting. Place the tube over the fitting and open a 1/2 turn. Remove the filler cap and let it gravity drain. Clean out the reservoir with paper towels. Fill with fuid and let gravity drain.
You can go faster by actuating the the cylinder. Make sure to keep filling the reservoir to keep air out. As a final bleed, I did it just like a car. Close the bleed, apply pressure to the actuator, open the bleed a 1/4 turn till the actuator depresses. Close the bleed, release the actuator. Repeat till your satisfied it's bled hard actuator/no bubbles in tube)."
