JHZR2
Staff member
Yeah, fortunately it isn't curb rash, but in some ways its more annoying because it means I was further away and literally millimeters was all it took to avoid this. Plus the repair is probably the same...
My driveway has one rather narrow section right before it goes alongside my house, and there are essentially curbs on either side to partition away from the grass on either side. I suppose it was done this way because my home is elevated from the street, so this reduced the angle of the slope.
Anyway, I was driving up, went a bit too far right, and felt the car lift up as the tire climbed the curve. What can you/do you do? Not much. Car went forward (hit it at just about the absolute end of the area where this structure is), and got out to inspect. Thought I was safe, but then I saw this:
Now, Im sure many would say to ignore it, but I am not interested in that and so I want to know about my options. Obviously I could:
1) Buy a new wheel
2) Buy a used wheel
3) Do an off-car replacement in a shop where the tire is unmounted
4) Do an on-car replacement from a mobile shop
Im not really keen on having an extra wheel laying around, and the damage is pretty minor. So #1 and 2 are more or less out.
So what are the pros/cons of the other two? I recall some say that repairs don't last and others have said they last for years. The car sees summer sun but no real road salt. Lots of brake dust though, especially in the winter when its tougher to wash the car.
What is the most likely repair approach? Would a shop that does off-car repairs, in a real shop, not a trailer, dismount the tire, and repaint the whole wheel, or would anyone with max access to materials, workspace, etc. usually only do a local repair, given this damage?
Is it possible to spot-fix it, or is full-wheel repaint the only acceptable method? I would imagine one would want to prevent the blending of paint on a wheel if they could.
Car is a 2011 135i with less than 10k.
Thanks!
1) Buy a new wheel
2) Buy a used wheel
Thanks!
