Originally Posted By: Kestas
Except you have to account for clingage loss.
Absolutely. When using it for ATF changes, I primarily use it as a reasonably accurate estimate for how much to pour back in after a drain. If I'm tidy and avoid spillage, I know that I will be close to the original fill level (+/- container calibration errors, clingage loss, temp differences between old and new ATF.) I will still double-check using the dipstick afterwards to make sure. Last time I did the drain & refill on my tranny, I didn't have to add anything. It was nice getting to the correct fill level in a single iteration.
For oil changes, I just like the fact that it has high sides and the container's mouth ends up being really close to the drain bolt when the car is up on ramps. My Subaru has such a large drain bolt that the oil tends to gush out at a fairly high velocity. With this "pan" I find it easier to keep the splashing contained. (No, I haven't install a Fumoto valve yet.)
