Kanling:
The bubble point test is run similar to flowing fluid "through" the filter. The filter element is sealed on both ends so that nothing can get by.
The filter is submersed in fluid. Then "Air" is sent through the filter, if memory serves, reversed flow. From inside the center tube area out through the filter element.
Any leak will show immediatly. Whether that be because of a hole in the media or a leak through the seam where the endcaps are ( E-core style or metal type). Or a leak through the seam where the pleats are joined.
here's a link showing the test equipment by an independant lab..
http://www.swri.edu/3PUBS/BROCHURE/D08/OILFILT/oilfilt.HTM
Well actually it shows other lab equipment as well.
Here's someones description of how they run the test:
Test that are typically conducted are:
Bubble Point
The bubble point test is based on the fact that for a given fluid and pore size, with constant wetting, the pressure required to force an air bubble through the pore is inversely proportional to the size of pore diameter. In practice, this infers that the pore size of a filter can be established by wetting the element with a fluid and measuring the pressure at which the first bubble stream is emitted from the upper surface of the element when air is applied from the underside.
The point at which the first stream of bubbles emerges is the largest pore. Therefore, the bubble point value can be used to obtain a relative measure of the size of the single largest pore in a filter element.
The relationship is based on Poiseuille's law which can be simplified to:
P = K/d
Where: K = an empirical constant dependent on the filter material, form and units of testing
Since this constant is essentially a capillary shape factor and is related to the material being tested as well as its form, it is easy to see why bubble point is typically only a relative comparison value for a given element and/or media.
10 LPM
The 10 LPM measurement is a continuation of the bubble point test. If after the bubble point is measured, the air flow is increased until the bubbles emerge from the second largest hole, then the third and so on until a point is reached where air bubbles appear over the entire surface of the element the open bubble point is reached. This open bubble is a relatively good measure of the mean pore size of an element provided there are no other restrictions or physical limitations.
Since this point can vary from filter to filter and media to media, SMP developed the 10 LPM (10 liters/min) test several years ago with one of its customers to establish a standard wet air flow test that could be used as a relative measure of the mean pore size of an element. This test provides a somewhat broader perspective of an element's mean pore size and ultimate integrity.
---Now you know more than you ever wanted to..lol
But the bubble point test is also used to test element integrity. As you can figure out now for yourself. Wonderful thing this internet thingy..
