No block and battery heaters?
Not at work. It sits there for 9 hours and then gets a cold start. It does have a block heater but is in a heated garage over night.No block and battery heaters?
Wow. That’s a good run. Like someone said, heat injures batteries and cold kills them. I find if you ever get a slow start, replace it. ( of course knowing someone didn’t accidentally leave the lights on ). I hate replacing batteries in a cold dark parking lots. Having said that, I like using a battery tester ( $50 bucks). I just posted that I have a seven year old 770 CCA battery that fades to 500 CCA in 24 hours after fully charging. That’s good enough for 32 F, but I have -25 F coming in January ( and I take it, so do you). Plus it’s my wife’s vehicle. Happy wife, happy life.Close to 10 years on the OE battery of my 2011 Hyundai Genesis Coupe which is only summer driven and it still seems to crank strong so I figure I'll just push it until it no longer functions.
Not sure what the failure mode is of batteries for vehicles only used in the summer though, can you gradually feel the crank getting weaker and weaker, or do they just fail to start one day? I usually get caught off guard in the winter because our temperatures can swing quite a bit day to day and you never really get a chance to "feel" the battery getting weak until you get hit by the surprise -40C day where it doesn't crank.
Of course. The starter is in the engine bay as well, no?Can I use the remote posts in the engine bay to load test?
Fair point!Of course. The starter is in the engine bay as well, no?
Pretty sure airport parking gives free jump starts. This happens often there.No start at 1230a after getting off a 3.5hr flight. Not messing around with it, grabbed an Uber home then replaced it in the morning w/ an Interstate from Costco.
Yeah, was parked at my office building a few min away from the airport. Uber driver graciously offered his car as a jump, wasn’t quite up to snuff unfortunately. Didn’t want to keep him waiting too long so I didn’t have it hooked up for too long before giving it a shot.Pretty sure airport parking gives free jump starts. This happens often there.
This should be stickied for all those that suggest a working four, five or six year old battery should automatically be replaced just because it's four, five or six years old.I replaced the battery in the 2008 Mercedes today. 13 years is a record for me!
Did you get rid of the battery? You can switch to the temperature display and with the car off, hit the reset button 3 times and it will display the voltage of the battery. Mine is also a 2008 and it has the date code on the terminal post. Mine was made in November so it's 14 years old now. Mine died on me last year, gave it a good charge and it's still going a year later. Still ok so far, display ranges from 11.5-11.9. I don't linger though.Timely thread. I replaced the battery in the 2008 Mercedes today. 13 years is a record for me!
Normally she cranked right over, no real cranking. Even in Winter just glow the plugs and vroom.
It just cranked slow Monday and Wednesday mornings when it was about 30 F. So I got one today. She had a good run.
The Blazer usually needs one every 5 or 6 years, as have most of my past vehicles.
Looks like you have the record!Did you get rid of the battery? You can switch to the temperature display and with the car off, hit the reset button 3 times and it will display the voltage of the battery. Mine is also a 2008 and it has the date code on the terminal post. Mine was made in November so it's 14 years old now. Mine died on me last year, gave it a good charge and it's still going a year later. Still ok so far, display ranges from 11.5-11.9. I don't linger though.
When it died last year, it was down to 11.2 volts. With the seat heater on and the lights and radio, you can watch it drop by .1 volts every minute or so with the engine off.Looks like you have the record!
I traded the battery in for $26. My voltage was down to 11.2 V so I just decided to go ahead and feel good about it.
A new MB battery makes the car run better too! Redline makes it run quieter, and Prestone makes it run cooler.
(Actually I've been using Castrol oil and she still has OE coolant)
