I have come to the conclusion that some add-packs are used to makeup for base oil short comings, and that add-packs can improve product specs. Based on this I have three questions:
1- Is it better to have a good base oil with a weak add-pack, or a weak base oil with a good add-pack?
2- How can you tell the quality of each from the product specs?
3- And finally, if a heavily beefed up add-pack is used [with a weak base oil], are there any concerns that will show up in the long term or from long OCI’s such as sludge or other effects?
