Originally Posted By: Miller88
Use their tool; I've generally had good luck with it in the past when AVG wouldn't remove itself.
Picking it clean yourself could get tricky, even if you remove all of the AVG files, there's still going to be a bunch of registry entries.
I used the tool, then checked the registry and there was a ton of junk remaining. I plucked as much as I could, a few lines couldn't be removed. Everything is fine now, and I'm done with AVG.
With my Windows XP, when I uninstall anti-virus programs thru "Add & Remove" in my Conrol Panel, I will always afterwards Click...
Start
Search
Look for Files and Folders
.... then type-in "AVG" and do a search.
I wil even advance it by looking in hidden files and folders.
Wherever I locate 'AVG', I delete it - right there on the spot. I've done this with AVG, McAfee, Norton, Avast, Avira, Ad-Aware....etc.
I am running MSE right now. Someday I might try Comodo.... heard that one was very good and somewhat-easy on XP resources.
