What I spend on my brake pads isn't an issue. I want my car to stop. And, you will appreciate that if you've ever driven down a mountain, or drive aggressively!
I'll stick with upgraded pads, if available, for my cars. I won't install generic cheap pads on any cars that I work on. I also won't do hack slap on pad replacement without replacing or turning rotors, bleeding thoroughly, lubeing, torquing, antisqueal spraying..........
Also, I don't care for how pads wear the rotors. Rotors are cheap and there is no excuse not to change them every couple of brake jobs. Most of my rotors last 100k+ without issues regardless if I used organic cheapos, semimetallics, ceramics, kevlar, or any other blend of pad material.
Concerning the Autozone pads, rumour has it they roll off the Satisfied assembly line, meaning that they are good OEM equivalent replacements. I wouldn't bother with them but you buy what you can afford. My life is worth an extra $20 for upgraded pads.
