Okay. I wan't to change the ATF fluid on my car to Max-life so the whole car can have synthetic fluid in it, Also due to the fact that when i'm off roading the transmission gets really hot and periodicity I have to let it cool down.
The manual only says how much to add to the transmission if you drain it from the drain plug which is 1.5 liters. (Not including what's in the torque converter or cooler lines. How many bottles do you think I should buy?
I've followed the 2 metal lines from the transmission and one leads to the steering rack and the other directly connected to the bottom of the radiator. I for one have never seen that before.
Could I drain the fluid from the pan, refill and repeat? This transmission comes with a non replaceable filter.
What do you think I should do? And is Max-life a good fluid choice for my car. It has about 45k miles on it and I want to run synthetic. My transmission uses Dextron ll or lll.
