Originally Posted By: BuickGN
Misfires make the sensor read rich which it tries to correct, making the normal cylinders go lean.
My line of reasoning:
A missfire (ignition missfire) will have raw hydrocarbons and air mixed together going out the exhaust. An O2 sensor measures exhaust O2 and nothing more, unburned hydrocarbons don't matter. Assuming no combustion takes place the exhaust O2 is very high as compared to a properly burned mix. O2 voltage production (in platinum sensors) is proportional to the delta between exhaust O2 and ambient O2.
Lean indications= low O2 voltage= high exhaust O2 content as there is not enough fuel present to use all of the O2 available.
Rich indication= high O2 voltage= low exhaust O2 content due to more fuel available to use the remaining O2.
Missfires jack up the available O2 in the exhaust for the O2 sensor to read. Higher O2 content in the exhaust equals a lean reading from the O2 which causes the PCM to richen the mix.
That's my story and I am stickin' to it.
