427Z06,
Ok lets see if I can get this right.
Its a 91 Dodge Stealth. Pulled the motor and replaced it with a 3rd gen 3000GT with 4 bolt main. Yanked the transmission and transfer case out, send them away and had the gearing and splines buffed up, as well as having an LSD installed (front and rear LSD's now). Splines were increased in both number and thickness, eliminating one of the 3000GT's chief weaknesses.
Stock ECU was replaced with an AEM EMS. Tuning was performed at altered atmosphere. Stock turbo's were replaced with Super 15G's
Injectors replaced with 550cc's (Going to put 720 or 760's in next (forget which is the right number)).
Intercoolers were replaced with considerabily larger ones, new ignition system, boost controller, intercooler/turbo piping, speed density airflow system instead of MAF/IAT based. Added an alcohol injection system (not included in the mapping) for safety reasons, which begins spraying at 16-17 psi. Turbo's run 16-18 psi on the street (depending on gear) and 20-22 on the track.
Last mod was the CF drive shaft which showed a 20-30 whp gain in 3rd gear pulls, depending on the dyno. (Over 50 runs there is always variance)
Oil is 15w-50 mobil1. Upcoming mods are stage 3 heads (ported and polished) with a portmatched intake plenum, and oversized valves.
Exhaust is HKS (no cats) with an HKS downpipe.
Final goal is 450-500 whp. As of right now, people with similar setups run high 11's. My father used to be an old school drag racer...i don't think his need for acceleration will ever be satisifed.
Driving the car right now is almost terrifying. If you aren't sitting back in the seat when the accelerator is depressed, it'll throw you down like a WWF wrestler. Shift and all 4 tires chirp
Here's a photo of the stealth's stock driveshaft (3 piece) and a replacement unit (alumnium in this instance). Gives you an idea of why an aftermarket one might result in a 1 lb = 1hp gain. Most owners see a 0.2 1/4 reduction from the CF driveshafts. (Dyno and Track proven)
[ February 20, 2005, 02:15 PM: Message edited by: crossbow ]
