Originally Posted By: Jetronic
the torque needed to drive the bolt drops as you go into the plastic range. The key is feeling when the needed torque is rising rapidly, and judging the purpose of the bolt. a plastic cover has small bolts and doesn't need/withstand much torque.
copper paste isn't a lubricant, as is anti-seize. Not like oil is anyway. a clean bolt will go into a clean thread more easy than with the paste on it.. the benefit comes next time you need to remove the bolt. crack it off, and remove with little or no effort vs fighting it all the way out, or snapping...
Oh today I figured I'd try copper paste as a thread sealer, and it worked. Needed to fit a new coupling on an air line. will see if it holds...
Please stop making things up. You will not feel the bolt go into the plastic range. By the time you feel it, as you describe, the bolt would go past its ultimate tensile strength and would be extremely close to breaking. It would also look like the example below the graph.
Below is the graph that I was thinking of when I was describing the ranges.
Here is an extreme example and a reason why TTY bolts should not be reused, or torqued with lube, if the specification calls for dry installation.
