Vehicle: 2004 Subaru WRX STi
Mileage: 73,200
Driving Style: Spirited
Current Fill: PP 5w30 with Purolator PureONE Filter
Air Filter: Amsoil EAO
So im trying to figure out which oil would offer me superior protection, lubrication and cleaning.
Both oils are in the upper 7-8 dollar range, and both oils are superior to most anything you can find on the shelf of any store.
When going to a new oil I ALWAYS start with a 3,000 mile OCI and then send away for analysis. And then extend furthur, I am a bit over protective of this vehicle.
Im running a good air filter so I think i'll have good filtration of particles, however I sometimes smell the hint of fuel on my oil.
If you are curious here is some comparative data.
Amsoil
AMSOIL Signature Series 0W-30 Synthetic Motor Oil (SSO)
Kinematic Viscosity @ 100°C, cSt (ASTM D445) 10.3
Kinematic Viscosity @ 40°C, cSt (ASTM D445) 56.56
Viscosity Index (ASTM D2270) 173
Cold Crank Simulator Apparent Viscosity @ -35°C, cP (ASTM D5293) 5927
Pour Point °C (°F) (ASTM D92) -51 (-60)
Flash Point °C (°F) (ASTM D92) 230 (446)
Fire Point °C (°F) (ASTM D92) 246 (475)
Four-Ball Wear Test (ASTM D4172: 40kgf, 150°C, 1800 rpm, 1 hr) Scar diameter, mm 0.406
Noack Volatility (ASTM D5800) 250°C for 1 hour, % weight loss 8.65
High Temperature/High Shear Viscosity cP, X°C, X s-1 (ASTM D4683) 3.2
Total Base Number 13.2
Redline
5w-30
SM/SL/SG/CF
Gas/Diesel
Viscosity Grade (SAE) : 5w-30
Vis @ 100 C, cSt : 10.6
Vis @ 40 C, cSt : 62
Viscosity Index : 162
CCS Viscosity Poise : 60@-30C
HTHS Vis, cP @150C : 3.8
ASTM D4741
Pour Point C : -45
Pour Point F : -49
Flash Point C : 252
Flash Point F : 486
NOACK Evaporation Loss
1hr @ 482F (250C), % : 6
What do you guys think?
*All Technical info was spotted by each oils respective website.
Mileage: 73,200
Amsoil
Redline
5w-30
SM/SL/SG/CF
Gas/Diesel
ASTM D4741
Pour Point C : -45
Pour Point F : -49
Flash Point C : 252
Flash Point F : 486
