Here is the result from my Blackstone report...Vehicle is a 2006 Jeep Grand Cherokee with 3.7L PowerTech V6. Most of my driving with this vehicle is in the Ozark Mountains pulling a 3k trailer. (Have to thrash the 3.7 up some of the grades) Edit: it is mostly highway.
Previous fill was M1. I've had this vehicle since new. The only time M1 wasn't used was once when the wife had Synpower put in at a quick lube (approx 20k miles ago).
PureOne filter.
No top-off oil added. (Never burned or leaked)
Fuel is only from Shell stations, and a bottle of Techron was added in the fuel tank a couple hundred miles before I switched to the Amsoil.
BLACKSTONE'S REPORT
"Joe, We're not sure what oil you were using before this Amsoil was put in use, but it probably was something that used sodium as an additive. Sodium in that form is harmless. If it's coolant, it can be abrasive, though that doesn't appear to be the case here. Wear metals read quite low compared to averages, which are based on 5,000 miles on the oil for the Jeep 3.7L V-6. You mentioned lots of towing and some revs in the hill, but judging by the low wear numbers, the engine doesn't mind. The TBN read 3.1, which shows plenty of active additive left. Nice report.
Code:
OIL Amsoil OE 5w30
MILES IN USE 4880
MILES 87070
SAMPLE TAKEN 6/11/12
ALUMINUM 3
CHROMIUM 0
IRON 7
COPPER 1
LEAD 0
TIN 0
MOLYBDENUM 79
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 79
SILICON 8
SODIUM 54
CALCIUM 2006
MAGNESIUM 124
PHOSPHORUS 710
ZINC 816
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 400
SUS VIS 210ºF 60.5
cSt @ 212ºF 10.37
FUEL % 0
TBN 3.1
Any questions and comments would be greatly appreciated.
As far as my experiences with the Amsoil OE, I must say that I've been very happy thus far and had better results on this UOA than I was expecting.
I'm not sure if i'm going to stay with the OE...its a great oil, but when shipping costs are added in it makes it real hard to stay with it. My dealer doesn't keep any Amsoil in stock so this will probably affect my decision next oil change. (After costs and shipping Amsoil OE is about $10 more expensive than locally available premium synthetics)
PureOne filter.
BLACKSTONE'S REPORT
Code:
OIL Amsoil OE 5w30
MILES IN USE 4880
MILES 87070
ALUMINUM 3
CHROMIUM 0
IRON 7
COPPER 1
LEAD 0
TIN 0
MOLYBDENUM 79
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 79
SILICON 8
SODIUM 54
CALCIUM 2006
MAGNESIUM 124
PHOSPHORUS 710
ZINC 816
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 400
SUS VIS 210ºF 60.5
cSt @ 212ºF 10.37
FUEL % 0
TBN 3.1
