quote:
Originally posted by digitaldrifter91:
sorrie if im whorin it up...but here is a switch and fuse method
http://www.civicland.com/diy/misc/fuelpupmpcutoffswitch.shtml
I have just had a read ove the article above and I am concerned about what this says to do. The author has upped his fuse rating to 25amps as he was blowing fuses. A REAL BIG NO NO!!!!! Fuses are rated according to the load and wire rating. They try to protect the wiring in case of a fault comdition.. If you put a higher rated fuse in then your wiring may then become the fuse!!! Most manufacturers wiring specifications are such that they will just be sufficient for the load. Japanese are probably the worst (or best depending on your point of view) as they allow no excess capacity at all.
Case study. My son recently upgarded his fuel pump on his Nissan 180sx to a higher rated Walpro unit. We were surprised how quiet it was, although they had a reputation for being quieter than standard. I checked the voltage across the pump and noted siginificantly lower voltages than normal. Also on feeling the wiring it was also warm. Obviously I could only feel the exposed parts. Checking back with the supplier and yes it needed upgraded wiring and without it the wiring was bound to burn through. Now, the standard fuse was not changed, nor did it blow!
Why was the voltage down and the wiring warm? Additional current draw over wiring that is offering too much resistance (eg too small a gauge) will cases heating - the greater current over a given rsistance = heat - and voltage drop.
So the solution. We had to rewire from front to back.
Now in the article you have quoted he is obviously drawing extra current as the standard fuse was blowing. A dangerous condition. As a standard fuse can continously take a large margin over the rating, burning of the wiring over time is a real possibility.
Sorry for my rant. Safety first. Car batteries are capable of huge amounts of current and I think sometimes people tend to forget this. They think it is just 12 volts, therefore it is safe.
[ January 09, 2004, 11:09 PM: Message edited by: theguru ]
