I guess I have not seen the all the negatives of an aluminum body pickup as others have. Semi truck tractors have been using aluminum extensively for a few decades. One can even spec full aluminum frames and drive axle housings. Cabs and sleepers are primarily aluminum. Many of them drop 120,000 miles a year running the rust belt of the country and hold up pretty well. Many of those are not even getting weekly truck washes. I suppose more expensive body work might be an issue if one has a propensity to bust their vehicle up on a regular basis, but insurance covers repairs and deductible is the same for the owner, so not sure it is all that big of a deal. Aluminum bodies are grommet mounted to steel frames. No interaction between metals.
I am just surprised it took so long for the auto/pickup OEM's to get on the aluminum band wagon.
I'd almost consider a semi being a different animal since it is just an aluminum cab riding high up on a frame. Plus it has huge wheel wells, some of which are fiberglass, keeping its own road spray down.
I dont think the salt that gets on the body would have anywhere to "hide" either. That is the issue with pickup trucks and other passenger cars. They have many cavities, nooks and crannies that allow salt to just sit there and not fully dry out. Mid 2000 Dodge trucks for example. Also the old boxy Cherokee XJ with their fender flares.
Talk to a commercial truck shop. Corrosion from salt and such is a major problem with wiring and other components. A semi has more nooks and crannies than many realize. And they get as much or more road spray up in them, and on top of them, as any other vehicle. I go thru several jugs of windshield washer a week in the winter months. But, I also make sure and do a complete truck wash and undercarriage wash after a major snow.
Something is definitely different about them though because as you said, they don't corrode. Panel trucks don't seem to have this issue either.
Do a quick google on aluminum corrosion on cars and Im sure you'll see plenty of it.
OTR trucks corrode like crazy, just not the panels themselves because they are aluminum or fiberglass. Everything under the hood is still steel and it rots.
