Sorry to drag this one up from the vault (was searching for something else...)
Anyway, interesting thoughts on greases used for alt bearings.
A FWIW is that in one of our diesel vehicles the rear alternator bearing is a very small INA needle roller that runs directly on the shaft. (appears to use a hardened, pressed on and non-replaceable sleeve...)
It also sits pretty closely to the turbine and dump pipe side of a turbocharger.
Surprisingly, the OE grease dies prematurely with the bearing soon after. (Magneti-Marelli
The trick is to re-grease the needle roller periodically.
When I first did it four or so years ago, I used some Neo Z12 grease I had, which is some sort of syn base oil with a Li complex thickener.
Never had a problem with it.
Six months ago when the front bearing started to die I replaced it and re-greased the rear bearing again with Redline's CV-2.
The brushes, etc seemed to be pretty clean, considering an unshielded bearing was pretty close by.
