Originally Posted By: K20FA5
Originally Posted By: unDummy
Matic K is used in Nissans equipped with Aisin transmissions. Give you a little hint, 3309/T-IV.
Any universal or multivehicle ATF mentioning Jaso-1a, 3309, or T-IV will work fine. Stick with a full synthetic.
Easy choices are Amsoil, Redline, RoyalPurple, Maxlife...
unDummy,
Do you know what the spec is on the Matic J/S? I'm going to be doing a 15K drain/fill on my Frontier soon. Thanks!
I have a Nissan Titan that had the Matic J. I ran 60k with BG universal synthetic with no problem. I replaced with Royal Purple Max ATF and it is perfect.
I would not opt for a spill and fill, but a full synthetic atf exchange...you can easily go 50-60k with that.
