- Joined
- Nov 29, 2009
- Messages
- 7,281
I was using my air die grinder when I noticed a little bit of air coming out of the handle part where there is a flathead adjustment screw. It wasn't 30 seconds and it started leaking a bunch more air. Is it just a matter of loosening up that big flathead insert. The screw that's inside the insert just turns and doesn't come out, but I'm assuming the bigger insert that surrounds it would if I can find a wide enough screw driver, which I don't think I have. I know the oring blew out because it was in the groove of the screw where I was sticking the screw driver.
