is there another product, such as paint or laquer thinner that acetone would be the main ingredient. I can't find it here in japan.
quote:
Originally posted by XS650:
quote:
Originally posted by moribundman:
I was guessing raspberry syrup, based on color and fruity smell, but what do I know?Syrup?well I donno if one treatment will do anything, you do have a modern car with a properly maintained filter... besides I even went so far as to dump coffee cups full of water in mine before... but I did have something to dump in and mix to remove the water too... I fugured out the ratios before I did the deed, though on that one.
Life is full of these ups and downs, I'm sure one time is not going to hurt.
Acetone is just hydrogen, carbon and oxygen (C3 H6 O) and is highly volatile. It might be easier on the cat converter than gasoline. It should not be problem for the sensor or cat in any case.quote:
Originally posted by Pat in Speedway:
I drank the grape Kool-Aid and put 6oz of acetone in my 23 gallon Caprice. I was talking with my brother about it (after I dumped it in there) and he posed a question: What's it going to do to your O2 sensor and/or catalytic converter? Good question, me thinks. Anyone been using this stuff long to have any adverse effects?
Most nail polish remover is just acetone...just not the lemon type.quote:
It appears your running the minimum amount recommended. Try 9oz. next time. Also be careful running to low on gas you'll burn up the fuel pump, several hundred bucks for a new one. They say you shouldn't go under a 1/4 of a tank.quote:
Originally posted by Vortec_4300:
I've run 6 oz. of acetone in my 30 gallon fuel tank on my 2005 Silverado.
I did this for three consecutive tankfulls, and ran the tank to empty each time. This is easy to do as I have a 100 round-trip commute to my current cleint site every day.
My fuel consumption has remained unchanged at 23.2 mpg for the 4.3l Vortec V6.
Then why even make a coment?quote:
Originally posted by Terry:
Troop. Wish I could be more specific but I can't.
From an i4 Camry ownerquote:
(a few months later) I went from an avg. of 24mpg to 26mpg overall... Now, I have run (this is my 3rd) tank of NON acetone fuel in the system. I am now avg. 25mpg. I only run 93 Chevron or Shell V-Power.
