quote:
Originally posted by rpn453:
How long have you had the car, Oil stain? Any previous maintenance records if not bought new?
My mother has about 100K miles on hers now. The oil always looks good.
It wasn't my car. A friend bought it from a family member. The kid only put about 1500 miles on it before it died.
Once I started taking the motor apart you could see the crud everywhere. Even the inside of the intake was really bad.
Right now I'm putting a reman v8 motor in a firebird for the same reason, a spun rod bearing. In the beginning of the year I put headers, a catback system and 1.6 rockers arms in. When I had the valve covers off and doing the work, the heads looked real clean like the owner really took care of the motor.
When she came to me about the rod bearing I thought she just over revved the motor. But to my surprise, once I took the intake off, there was the crud. It was caked everywhere. It reminded me of the stuff that sits in the bottom of the BBQ.
So, the point is that even after looking in the oil filler hole or taking off the valve covers to check what you would think would be a clean running engine, can lie to you because someone had a valve job. Which as you know the heads get cleaned up.
To sum up, you never really know what your buying.
I happen to have taken a picture of the motor. The crud was real flakey and about 3/8" deep.
You can even see the gaskets didn't seal well. It's no wonder the bearing went. It clogged an oil passage somewhere.
[ September 05, 2006, 09:19 PM: Message edited by: Oil stain ]
